Ana içeriğe geç
Disassembling Panasonic GU87 Main-LCD
Neye ihtiyacın var
  1. Disassembling Panasonic GU87 Main-LCD, LCD Cover removal: adım 1, 1 resimden 1.
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 Main-LCD: adım 2, 1 resimden 1.
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 Main-LCD, LCD: adım 3, 1 resimden 1.
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 Main-LCD: adım 4, 1 resimden 1.
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
  5. Disassembling Panasonic GU87 Main-LCD, Main Board: adım 5, 1 resimden 1.
    • Unlock the LCD connectors shown in red boxes on the picture .
    • Use tweezers as necessary.
  6. Disassembling Panasonic GU87 Main-LCD: adım 6, 1 resimden 1.
    • Place finger nails on the connector tab as shown.
    • Lift the connector tab up.
  7. Disassembling Panasonic GU87 Main-LCD: adım 7, 1 resimden 1.
    • Pull/pivot the LCD main board as shown in order to remove.
  8. Disassembling Panasonic GU87 Main-LCD, Disassembling Panasonic GU87 Main-LCD: adım 8, 1 resimden 1.
    • Use tweezers to lift up the main LCD.
Sonuç
Van
7 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-10, Johann Summer 2010 Cal Poly, Team 2-10, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G10
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,201
