Giriş
The lens can be safely removed in only seven simple steps.
Parçalar
Hiçbir parçaya gerek yok.
  1. Remove the following eleven screws securing the covers to the ZS3
    • Remove the following eleven screws securing the covers to the ZS3
      • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Remove the two LCD board ribbon cables out of their sockets.
    • Remove the three black screws that surround the lens.
      • 3mm Phillips screws
    • Using a spudger, flip up the locking flaps on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Disconnect the LCD ribbons gently using the spudger.
    • Using your fingers or a spudger, gently remove the lens mechanism from the rest of the camera.
      • Unlock lens mechanism located on the bottom of the device using your fingers.
      • Be sure to not use excessive force to avoid damaging any parts.
Sonuç
Kellen Ericson
10 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G60
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 6
Her zaman: 2,601
