Ana içeriğe geç
Disassembling Pentax K200D Front Cover
Neye ihtiyacın var
  1. Disassembling Pentax K200D Front Cover, Preparation: adım 1, 1 resimden 1.
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
  2. Disassembling Pentax K200D Front Cover, Flash: adım 2, 1 resimden 1.
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Disassembling Pentax K200D Front Cover, Bottom cover: adım 3, 1 resimden 1.
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
  4. Disassembling Pentax K200D Front Cover: adım 4, 1 resimden 1.
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Rick Nelson
706 İtibar
1 Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.699 adet Kılavuz yazıldı
Bir Yorum
How do l clean the prisum…
brett_lorking - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 82
Her zaman: 6,868
