Ana içeriğe geç
Disassembling Pentax K200D Front Cover
Neye ihtiyacın var
  1. Disassembling Pentax K200D Front Cover, Preparation: adım 1, 1 resimden 1.
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
  2. Disassembling Pentax K200D Front Cover, Flash: adım 2, 1 resimden 1.
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
    What if you are disassembling the camera because it wont turn on. If you cant pop up the flash is there a work around?
    Sean D99 - Yanıt
  3. Disassembling Pentax K200D Front Cover, Bottom cover: adım 3, 1 resimden 1.
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
  4. Disassembling Pentax K200D Front Cover: adım 4, 1 resimden 1.
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Rick Nelson
706 İtibar
1 Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
326 Üyeler
1.672 adet Kılavuz yazıldı
1Rehber Yorum
How do l clean the prisum…
brett_lorking - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 85
Her zaman: 6,877
