Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Retrieve your Pentax K200D, the lens mount cover, and required tools.
Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
With the camera turned on, press the pop-up flash button to release the flash.
Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
9 farklı kişi bu kılavuzu tamamladı.
