Ana içeriğe geç
Disassembling Pentax Optio S4i Lens Assembly
Neye ihtiyacın var
  1. Disassembling Pentax Optio S4i Lens Assembly, Front and Back Cover: adım 1, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly, Front and Back Cover: adım 1, 2 resimden 2.
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Disassembling Pentax Optio S4i Lens Assembly: adım 2, 1 resimden 1.
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Disassembling Pentax Optio S4i Lens Assembly: adım 3, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 3, 2 resimden 2.
    • Carefully pull the back of casing away from the front.
  4. Disassembling Pentax Optio S4i Lens Assembly: adım 4, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 4, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 4, 3 resimden 3.
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Disassembling Pentax Optio S4i Lens Assembly: adım 5, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 5, 2 resimden 2.
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. Disassembling Pentax Optio S4i Lens Assembly, LCD: adım 6, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly, LCD: adım 6, 2 resimden 2.
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Disassembling Pentax Optio S4i Lens Assembly: adım 7, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 7, 2 resimden 2.
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
  8. Disassembling Pentax Optio S4i Lens Assembly: adım 8, 1 resimden 1.
    • Pull the cover plate off for the two power cord jacks.
  9. Disassembling Pentax Optio S4i Lens Assembly: adım 9, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 9, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 9, 3 resimden 3.
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Disassembling Pentax Optio S4i Lens Assembly: adım 10, 1 resimden 1.
    • Remove the orange tape on top of the SD cardholder.
  11. Disassembling Pentax Optio S4i Lens Assembly: adım 11, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 11, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 11, 3 resimden 3.
    • Open the battery cover and lift plastic piece off.
  12. Disassembling Pentax Optio S4i Lens Assembly: adım 12, 1 resimden 1.
    • Remove tape on left side of camera.
  13. Disassembling Pentax Optio S4i Lens Assembly: adım 13, 1 resimden 1.
    • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
  14. Disassembling Pentax Optio S4i Lens Assembly: adım 14, 1 resimden 1.
    • Remove top left LCD bracket.
    • This is a small piece, be careful not to lose it.
  15. Disassembling Pentax Optio S4i Lens Assembly: adım 15, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 15, 2 resimden 2.
    • Push down bottom left LCD bracket to release the LCD from grip.
  16. Disassembling Pentax Optio S4i Lens Assembly: adım 16, 1 resimden 1.
    • Gently lift up LCD screen.
  17. Disassembling Pentax Optio S4i Lens Assembly: adım 17, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 17, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 17, 3 resimden 3.
    • Slowly pull LCD screen to the left to remove it from the other grips.
    • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
  18. Disassembling Pentax Optio S4i Lens Assembly, Lens Assembly: adım 18, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly, Lens Assembly: adım 18, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly, Lens Assembly: adım 18, 3 resimden 3.
    • Lift up tape slightly on both sides of speaker.
  19. Disassembling Pentax Optio S4i Lens Assembly: adım 19, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 19, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 19, 3 resimden 3.
    • Use the pointed end of a spudger to lift up brackets.
    • Lift speaker cover out.
  20. Disassembling Pentax Optio S4i Lens Assembly: adım 20, 1 resimden 1.
    • Remove speaker cover.
  21. Disassembling Pentax Optio S4i Lens Assembly: adım 21, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 21, 2 resimden 2.
    • Turn camera to front.
    • Carefully peel off orange wire tape. The tape is glued to the surface indicated.
    • Lift speaker from holder.
  22. Disassembling Pentax Optio S4i Lens Assembly: adım 22, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 22, 2 resimden 2.
    • Use a wedge to lift up the wire tape flap.
  23. Disassembling Pentax Optio S4i Lens Assembly: adım 23, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 23, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 23, 3 resimden 3.
    • Insert the point of a spudger underneath the wire shown.
  24. Disassembling Pentax Optio S4i Lens Assembly: adım 24, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 24, 2 resimden 2.
    • Carefully lift the wire out of the crevasses.
  25. Disassembling Pentax Optio S4i Lens Assembly: adım 25, 1 resimden 1.
    • Slowly bend the speaker's wire tape away from the lens assembly. Avoid creasing the tape.
  26. Disassembling Pentax Optio S4i Lens Assembly: adım 26, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 26, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 26, 3 resimden 3.
    • Remove indicated screws:
    • Three Black 3.80mm Phillips #00 screws.
  27. Disassembling Pentax Optio S4i Lens Assembly: adım 27, 2 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 27, 2 resimden 2.
    • Remove the indicated black 3.40mm Phillips #00 screw on the bottom of the camera.
    • Remove copper leads.
  28. Disassembling Pentax Optio S4i Lens Assembly: adım 28, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 28, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 28, 3 resimden 3.
    • Unscrew the indicated 3.80mm Phillips #00 screw on the back of the camera.
    • Remove screw and bracket.
  29. Disassembling Pentax Optio S4i Lens Assembly: adım 29, 1 resimden 1.
    • Turn the camera over to the front.
    • In the following step, you will undo the indicated pegs. PROCEED TO THE NEXT STEP.
  30. Disassembling Pentax Optio S4i Lens Assembly: adım 30, 3 resimden 1. Disassembling Pentax Optio S4i Lens Assembly: adım 30, 3 resimden 2. Disassembling Pentax Optio S4i Lens Assembly: adım 30, 3 resimden 3.
    • Carefully holding the camera, grab the corresponding two points.
    • Carefully twist the lens assembly away from you. You will be turning your hand clockwise.
    • Pull lens assembly out.
    • The lens assembly is attached to the logic board by wire tape.
Sonuç
Bassem Tossoun
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-29, Regan Winter 2011 Cal Poly, Team 4-29, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G29
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Do you have this disassembly steps for the S12?
ThoH - Yanıt
Lens will Not focuscorrectly
ThoH - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 2,261
