Ana içeriğe geç
Disassembling Pentax PZ-10 Top Cover
Neye ihtiyacın var
  1. Disassembling Pentax PZ-10 Top Cover, Top Cover: adım 1, 1 resimden 1.
    • The top cover is one piece encasing the top of the device except the shutter release button and flash.
  2. Disassembling Pentax PZ-10 Top Cover, Removing Upper Right Housing Screw: adım 2, 2 resimden 1. Disassembling Pentax PZ-10 Top Cover, Removing Upper Right Housing Screw: adım 2, 2 resimden 2.
    • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
    • Using the J0 screwdriver, remove the 6.3 mm screw.
  3. Disassembling Pentax PZ-10 Top Cover, Removing Screw in Battery Compartment: adım 3, 2 resimden 1. Disassembling Pentax PZ-10 Top Cover, Removing Screw in Battery Compartment: adım 3, 2 resimden 2.
    • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
    • Remove the 6.3 mm screw using a J0 screwdriver.
  4. Disassembling Pentax PZ-10 Top Cover, Removing Screw Under Flash Bulb: adım 4, 2 resimden 1. Disassembling Pentax PZ-10 Top Cover, Removing Screw Under Flash Bulb: adım 4, 2 resimden 2.
    • The next screw is found in the overhanging piece just above the lens.
    • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
  5. Disassembling Pentax PZ-10 Top Cover, Pulling Off the Top Cover: adım 5, 2 resimden 1. Disassembling Pentax PZ-10 Top Cover, Pulling Off the Top Cover: adım 5, 2 resimden 2.
    • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jonathan Diaz
213 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Thank you! Well done sir!
michaelsteele1953 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,077
