Giriş
Swingarm removal is required to access the rear tire and brakes.
Neye ihtiyacın var
Loosen the exhaust strap:
Use an 12mm wrench to loosen the exhaust band lock nut.
A 6mm Allen key is required to unscrew the bolt at the bottom of the band.
Once the bottom of the strap is loose, you can push it upward and slide the retaining pin that secures the top of the strap out to release it.
Remove the 15mm nut securing the upper front corner of the swingarm.
Remove the 15mm nut securing the lower front corner of the swing arm.
Remove the 24mm rear hub nut. Having a friend hold the rear brake handle will help break it loose. You can also use an impact wrench to remove it if you cannot get enough torque with a hand ratchet.
There is a spacer behind the rear hub nut. It will slide off with little or no force.
2 farklı kişi bu kılavuzu tamamladı.
