Giriş
Removing the frame will allow access to the eyes and solenoid should they need replacement.
Parçalar
Hiçbir parçaya gerek yok.
  1. Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun. Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Remove the regulator by unscrewing it in a clockwise direction. Remove the regulator by unscrewing it in a clockwise direction.
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Use the 5/64" hex key to remove the screw shown. Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Flip the marker over and use the 5/64" hex key to remove the screw shown.
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  6. Carefully remove the 9V battery and connector. Remove the 9V battery from the connector.
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  7. Carefully disconnect the three connectors from the circuit board. Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  8. Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise. Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  9. Be very careful during the step to avoid damage to the solenoid or wiring.
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
Sonuç
nicholasj6
261 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G42
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 224
