Ana içeriğe geç
Disassembling Planet Eclipse Etha Frame
Neye ihtiyacın var
  1. Disassembling Planet Eclipse Etha Frame, Regulator: adım 1, 2 resimden 1. Disassembling Planet Eclipse Etha Frame, Regulator: adım 1, 2 resimden 2.
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Planet Eclipse Etha Frame: adım 2, 2 resimden 1. Disassembling Planet Eclipse Etha Frame: adım 2, 2 resimden 2.
    • Remove the regulator by unscrewing it in a clockwise direction.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: adım 3, 2 resimden 1. Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: adım 3, 2 resimden 2.
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Planet Eclipse Etha Frame: adım 4, 1 resimden 1.
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Planet Eclipse Etha Frame: adım 5, 2 resimden 1. Disassembling Planet Eclipse Etha Frame: adım 5, 2 resimden 2.
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Planet Eclipse Etha Frame, Frame: adım 6, 2 resimden 1. Disassembling Planet Eclipse Etha Frame, Frame: adım 6, 2 resimden 2.
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Planet Eclipse Etha Frame: adım 7, 2 resimden 1. Disassembling Planet Eclipse Etha Frame: adım 7, 2 resimden 2.
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Planet Eclipse Etha Frame: adım 8, 1 resimden 1.
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
    FixBot'a Sor
    Yorum Ekle
Sonuç
nicholasj6
261 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G42
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 661
