Ana içeriğe geç
Disassembling PlayStation 2 Slimline Outer Shell
Neye ihtiyacın var
  1. Disassembling PlayStation 2 Slimline Outer Shell, Outer Shell: adım 1, 1 resimden 1.
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. Disassembling PlayStation 2 Slimline Outer Shell: adım 2, 3 resimden 1. Disassembling PlayStation 2 Slimline Outer Shell: adım 2, 3 resimden 2. Disassembling PlayStation 2 Slimline Outer Shell: adım 2, 3 resimden 3.
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. Disassembling PlayStation 2 Slimline Outer Shell: adım 3, 3 resimden 1. Disassembling PlayStation 2 Slimline Outer Shell: adım 3, 3 resimden 2. Disassembling PlayStation 2 Slimline Outer Shell: adım 3, 3 resimden 3.
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. Disassembling PlayStation 2 Slimline Outer Shell: adım 4, 3 resimden 1. Disassembling PlayStation 2 Slimline Outer Shell: adım 4, 3 resimden 2. Disassembling PlayStation 2 Slimline Outer Shell: adım 4, 3 resimden 3.
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Thomas Sullivan
3.927 İtibar
6 adet Kılavuz yazıldı
3 Yorum
Just to clarify: in order to FULLY remove the bottom half of the shell on my PS2 Slim, I had to remove a screw that pinned the controller ports in place; it's at the front, right between the Player 1 and Player 2 ports.
Other than that, this guide worked perfectly! :D
Kizul Emeraldfire - Yanıt
Good morning. Hello. The disassembly of the PS2 series 7XXXX (PS2 Slim) is very well explained, except for one detail. Indeed, when I started to separate the bottom from the top, a small metal plate with a threaded hole in the center. And I find no mention of it anywhere. Considering the part, I think it's used by one of the screws that holds the two plastic hulls, but I don't see where. Can you help me, please? Friendly, Marc.
Translated with www.DeepL.com/Translator
Marc Blériot - Yanıt
The metal plate with a screw hole in the middle is for the stand-up-base-stand to be screwed down. It’s an after market item SONY sold seperately.
김동현 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 122
Her zaman: 10,898
