Giriş
The Polaroid a520 Camera cover may be removed/disassembled by the consumer at home, with no need for manufacturer involvement. This guide will assist users in the process by showing step-by-step which components should be removed for this purpose.
Note: this guide is only for the purpose of aiding in repairs to the Polaroid a520, and only for repairs that may be accessed through the battery cover.
Neye ihtiyacın var
Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
Under the screen, locate the black plastic strip that sits above the white plastic strip.
Remove the four 6mm screws from the inner casing using a Phillips #00 screwdriver.
