Ana içeriğe geç
Polaroid a520 LCD Screen Replacement
Neye ihtiyacın var
  1. Polaroid a520 LCD Screen Replacement, Battery: adım 1, 2 resimden 1. Polaroid a520 LCD Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Polaroid a520 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the batteries from the camera.
  3. Polaroid a520 LCD Screen Replacement, Casing: adım 3, 1 resimden 1.
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Polaroid a520 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Polaroid a520 LCD Screen Replacement, LCD Screen: adım 5, 1 resimden 1.
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Polaroid a520 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
Sonuç
Dani
21 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-3, Johann Summer 2010 Cal Poly, Team 3-3, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S3G3
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,684
