Ana içeriğe geç
Disassembling Power Mac G4 M5183 DVD-ROM Drive
Neye ihtiyacın var
  1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 2.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: adım 2, 2 resimden 1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: adım 2, 2 resimden 2.
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Disassembling Power Mac G4 M5183 DVD-ROM Drive: adım 3, 1 resimden 1.
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Disassembling Power Mac G4 M5183 DVD-ROM Drive: adım 4, 3 resimden 1. Disassembling Power Mac G4 M5183 DVD-ROM Drive: adım 4, 3 resimden 2. Disassembling Power Mac G4 M5183 DVD-ROM Drive: adım 4, 3 resimden 3.
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
  5. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: adım 5, 3 resimden 1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: adım 5, 3 resimden 2. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: adım 5, 3 resimden 3.
    • Remove DVD drive from the drive bay.
    • Lift the two metal tabs on the back of the shielding and remove.
    • Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
    • Slide out DVD drive.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Stephen Scruggs
2.238 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G24
4 Üyeler
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 11,239
