Ana içeriğe geç
Disassembling Quasar Microwave Outer Cover
Neye ihtiyacın var
  1. Disassembling Quasar Microwave Outer Cover, Disassembling Quasar Microwave Outer Cover: adım 1, 1 resimden 1.
    • Disconnect the power supply cord from the outlet.
  2. Disassembling Quasar Microwave Outer Cover: adım 2, 2 resimden 1. Disassembling Quasar Microwave Outer Cover: adım 2, 2 resimden 2.
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Disassembling Quasar Microwave Outer Cover: adım 3, 2 resimden 1. Disassembling Quasar Microwave Outer Cover: adım 3, 2 resimden 2.
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Disassembling Quasar Microwave Outer Cover: adım 4, 3 resimden 1. Disassembling Quasar Microwave Outer Cover: adım 4, 3 resimden 2. Disassembling Quasar Microwave Outer Cover: adım 4, 3 resimden 3.
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Samuel
142 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G12
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 2,513
