Ana içeriğe geç
Giriş
In this guide, we will go through disassembling your device's case to access internal components
  1. Use a philips #00 screwdriver to unscrew both 4.064mm screws at the top of the device which hold it together. Use a philips #00 screwdriver to unscrew both 4.064mm screws at the top of the device which hold it together.
    • Use a philips #00 screwdriver to unscrew both 4.064mm screws at the top of the device which hold it together.
  2. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  3. Press a plastic opening tool into the space between the front and back portions of the case. Run it along the perimeter of the device to unhook the many plastic tabs.
    • Press a plastic opening tool into the space between the front and back portions of the case.
    • Run it along the perimeter of the device to unhook the many plastic tabs.
    • Gently pull both sides apart.
    • The speaker is connected to the back cover so be careful when separating
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Stephen Radachy
807 İtibar
5 adet Kılavuz yazıldı
Takım
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G5
2 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
boi this it too easy
murphy mcgrath - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 2
Son 30 Gün: 2
Her zaman: 596
