Ana içeriğe geç
Disassembling Rival 16131 Toaster Shell
Neye ihtiyacın var
  1. Disassembling Rival 16131 Toaster Shell, Shell: adım 1, 2 resimden 1. Disassembling Rival 16131 Toaster Shell, Shell: adım 1, 2 resimden 2.
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Rival 16131 Toaster Shell: adım 2, 2 resimden 1. Disassembling Rival 16131 Toaster Shell: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Rival 16131 Toaster Shell: adım 3, 3 resimden 1. Disassembling Rival 16131 Toaster Shell: adım 3, 3 resimden 2. Disassembling Rival 16131 Toaster Shell: adım 3, 3 resimden 3.
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Rival 16131 Toaster Shell: adım 4, 1 resimden 1.
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Naomi Willis
80 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 2-8, Propen Fall 2012 Cal Poly, Team 2-8, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G8
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 47
Her zaman: 4,641
