Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide tells you how to remove the back or rear panel of the Samsung Epic 4G, which is an important first step in working with the internal parts of the phone.
  1. Slide your fingernail along the edge of the device and pull at the plastic backing.
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. TÜM SEKMELERİ AÇ
    Mac için RAM Yükseltme Kit'leri
    Kit Satın Al
    Tüm Sekmeler İçin Yeterli RAM
    Kit Satın Al
  3. Pull at the plastic backing gently to remove it after hearing the snap sound.
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Andrew Cunningham
273 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G25
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 789
