Ana içeriğe geç
Disassembling Samsung Galaxy Ace Logic Board
Neye ihtiyacın var
  1. Disassembling Samsung Galaxy Ace Logic Board, Logic Board: adım 1, 2 resimden 1. Disassembling Samsung Galaxy Ace Logic Board, Logic Board: adım 1, 2 resimden 2.
    • Remove the battery cover and the battery
  2. Disassembling Samsung Galaxy Ace Logic Board: adım 2, 2 resimden 1. Disassembling Samsung Galaxy Ace Logic Board: adım 2, 2 resimden 2.
    • Remove the 7 silver screws with a Phillips #000 screw driver.
    • Sometimes the green one could be a little difficult. Use a tweezer for get it out.
  3. Disassembling Samsung Galaxy Ace Logic Board: adım 3, 3 resimden 1. Disassembling Samsung Galaxy Ace Logic Board: adım 3, 3 resimden 2. Disassembling Samsung Galaxy Ace Logic Board: adım 3, 3 resimden 3.
    • Lift gently the back cover from the screen assembly from the bottom.
  4. Disassembling Samsung Galaxy Ace Logic Board: adım 4, 2 resimden 1. Disassembling Samsung Galaxy Ace Logic Board: adım 4, 2 resimden 2.
    • Use a flat tweezer for take off the flexible on/off button from the frame.
    • Be careful, the flexible is very delicate; it could be cut if you go too fast.
  5. Disassembling Samsung Galaxy Ace Logic Board: adım 5, 3 resimden 1. Disassembling Samsung Galaxy Ace Logic Board: adım 5, 3 resimden 2. Disassembling Samsung Galaxy Ace Logic Board: adım 5, 3 resimden 3.
    • Use a flat tweezer and take off gently Flexible volume button from the left side.
    • Do the same for the right side.
    • Then lift the flex slowly, if you go fast you may cut the cable.
  6. Disassembling Samsung Galaxy Ace Logic Board: adım 6, 1 resimden 1.
    • Lift the microphone from the logic board.
    How can you replace the microphone?
    Henna - Yanıt
  7. Disassembling Samsung Galaxy Ace Logic Board: adım 7, 3 resimden 1. Disassembling Samsung Galaxy Ace Logic Board: adım 7, 3 resimden 2. Disassembling Samsung Galaxy Ace Logic Board: adım 7, 3 resimden 3.
    • Lift the sensor/earpiece cable with the opening tool.
    • Don't force, you may damage the soldering.
  8. Disassembling Samsung Galaxy Ace Logic Board: adım 8, 3 resimden 1. Disassembling Samsung Galaxy Ace Logic Board: adım 8, 3 resimden 2. Disassembling Samsung Galaxy Ace Logic Board: adım 8, 3 resimden 3.
    • Lift the logic board from the right side.
    • Use the removal tool to unplug the display cable from the logic board.
    • You can now separate the Logic board from the display assembly.
  9. Disassembling Samsung Galaxy Ace Logic Board: adım 9, 2 resimden 1. Disassembling Samsung Galaxy Ace Logic Board: adım 9, 2 resimden 2.
    • Use the removal tool to unclip the camera module from the Logic board.
  10. Disassembling Samsung Galaxy Ace Logic Board: adım 10, 3 resimden 1. Disassembling Samsung Galaxy Ace Logic Board: adım 10, 3 resimden 2. Disassembling Samsung Galaxy Ace Logic Board: adım 10, 3 resimden 3.
    • Use the removal tool or a spudger to unplug speaker module cable
    • And separate the speaker module from Logic board.
    • Be caution, the module is fixed by plastic teeth to the Logic board. Don't force, just make little wave-movements and the speaker comes on his own.
  11. Disassembling Samsung Galaxy Ace Logic Board: adım 11, 1 resimden 1.
    • Now you can work with the Logic board.
Sonuç
34 farklı kişi bu kılavuzu tamamladı.
finster
1.986 İtibar
1 Kılavuz yazıldı
2 Yorum
Thanks for the post. This is really Helpful
Dave Dayanan - Yanıt
im curently selling one thx to you
Kyle at work - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 26,698
