Ana içeriğe geç
Disassembling Samsung Gear 2 Front half and Back half
Neye ihtiyacın var
  1. Disassembling Samsung Gear 2 Front half and Back half, Front half and Back half: adım 1, 2 resimden 1. Disassembling Samsung Gear 2 Front half and Back half, Front half and Back half: adım 1, 2 resimden 2.
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Disassembling Samsung Gear 2 Front half and Back half: adım 2, 1 resimden 1.
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Disassembling Samsung Gear 2 Front half and Back half: adım 3, 3 resimden 1. Disassembling Samsung Gear 2 Front half and Back half: adım 3, 3 resimden 2. Disassembling Samsung Gear 2 Front half and Back half: adım 3, 3 resimden 3.
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jonathan Molina
1.018 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G27
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,234
