Ana içeriğe geç
Disassembling Samsung Gravity SGH-T459 Rear Case
Neye ihtiyacın var
  1. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Back Cover: adım 1, 1 resimden 1.
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Battery: adım 2, 1 resimden 1.
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: adım 3, 3 resimden 1. Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: adım 3, 3 resimden 2. Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: adım 3, 3 resimden 3.
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 356
