Ana içeriğe geç
Disassembling the Samsung Laptop Ultrabook NP530U3B
Neye ihtiyacın var
  1. Disassembling the Samsung Laptop Ultrabook NP530U3B, Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 1, 1 resimden 1.
    • Remove the 8 small screws.
  2. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 2, 2 resimden 1. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 2, 2 resimden 2.
    • Remove the other 6 screws.
    • Remove the hard disk and the RAM slots.
  3. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 3, 1 resimden 1.
    • This is the hard disk - Hitachi 500 GB
  4. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 4, 1 resimden 1.
    • Ensure that the hard disk has been removed. Carefully detach the bottom cover.
  5. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 5, 1 resimden 1.
    • Once the bottom cover is removed, your device should look like this.
  6. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 6, 1 resimden 1.
    • Remove the 4 screws to detach the battery.
    • Remove all of the sticky tape.
    • Carefully disconnect the small power connector by using a tool to push the connector out through the small gap in the middle of the connector.
    • The connector won't come out all the way, because the battery pack is in its way.
  7. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 7, 2 resimden 1. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 7, 2 resimden 2.
    • This is the Samsung 7.4V 45Wh battery.
    • Ensure that the battery is removed before continuing.
  8. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 8, 1 resimden 1.
    • When the battery is removed, this is how it will look.
  9. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 9, 1 resimden 1.
    • Remove the processor fan.
    • There are 2 screws holding it in place. Loosen and remove them.
  10. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 10, 1 resimden 1.
    • This is the processor fan.
  11. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 11, 1 resimden 1.
    • Remove the processor heat sink.
    • 3 screws hold this part in place. Loosen and remove them.
  12. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 12, 1 resimden 1.
    • Disconnect the antenna cables from the WiFi card.
    • Remove the screw.
    • Be sure to match the colors when reattaching the cables.
  13. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 13, 1 resimden 1.
    • Remove the screw.
    • Lift the latch upwards to loosen the cable.
  14. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 14, 1 resimden 1.
    • Remove the screw.
  15. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 15, 1 resimden 1.
    • Remove the screw.
  16. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 16, 1 resimden 1.
    • To remove the Motherboard, carefully disconnect the cables.
  17. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 17, 2 resimden 1. Disassembling the Samsung Laptop Ultrabook NP530U3B: adım 17, 2 resimden 2.
    • This is the Motherboard - there is a front and rear view.
Sonuç
34 farklı kişi bu kılavuzu tamamladı.
Jose Gustavo Abreu Murta
4.598 İtibar
9 adet Kılavuz yazıldı
30 Yorum
Hello,
Do you know where can i reset the Bios CMOS in that motherboard?
I think there are people who wants to know becose system upgrade is leading to bios ACPI Error.
Thanks for your help
Luis Orland - Yanıt
No, I do not know where is a reset pin of BIOS.
Try to disconnect NVRAM battery.
Wait 15 minutes and reconnect again.
Jose Gustavo Abreu Murta - Yanıt
To reset BIOS this NP530U3, only disconnect all power supply (MAIN battery, CMOS battery and power source). And hold press POWER button for 1 min.
warmdk - Yanıt
I try it but don't work, do you know another way to do this
manhique -
Hello,
I have seen many screens with model number LTN140AT21-XXX for this laptop. My laptop NP530u4b has a screen LTN140AT21-802. I would like to know if I can use a LTN140AT21-002 screen, or if only is good a screen with number LTN140AT21-8.
thanks for your help.
alex - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 75
Her zaman: 52,903
