Ana içeriğe geç
Samsung SPH-A760 Speakers Replacement
Neye ihtiyacın var
  1. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: adım 1, 2 resimden 1. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Battery: adım 1, 2 resimden 2.
    • Push open the latch and remove the battery.
  2. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: adım 2, 2 resimden 1. Samsung SPH-A760 Speakers Replacement, Disassembling Samsung SPH-A760 Antenna: adım 2, 2 resimden 2.
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Samsung SPH-A760 Speakers Replacement, Logic Board: adım 3, 1 resimden 1.
    • Remove the five screws as shown.
  4. Samsung SPH-A760 Speakers Replacement: adım 4, 1 resimden 1.
    • Carefully pry the back plate off.
  5. Samsung SPH-A760 Speakers Replacement: adım 5, 2 resimden 1. Samsung SPH-A760 Speakers Replacement: adım 5, 2 resimden 2.
    • Carefully detach golden screen connector.
  6. Samsung SPH-A760 Speakers Replacement: adım 6, 2 resimden 1. Samsung SPH-A760 Speakers Replacement: adım 6, 2 resimden 2.
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Samsung SPH-A760 Speakers Replacement: adım 7, 2 resimden 1. Samsung SPH-A760 Speakers Replacement: adım 7, 2 resimden 2.
    • Place the logic board on a clean tray.
  8. Samsung SPH-A760 Speakers Replacement, Speakers: adım 8, 2 resimden 1. Samsung SPH-A760 Speakers Replacement, Speakers: adım 8, 2 resimden 2.
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Samsung SPH-A760 Speakers Replacement: adım 9, 3 resimden 1. Samsung SPH-A760 Speakers Replacement: adım 9, 3 resimden 2. Samsung SPH-A760 Speakers Replacement: adım 9, 3 resimden 3.
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Samsung SPH-A760 Speakers Replacement: adım 10, 3 resimden 1. Samsung SPH-A760 Speakers Replacement: adım 10, 3 resimden 2. Samsung SPH-A760 Speakers Replacement: adım 10, 3 resimden 3.
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
Sonuç
David
25 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-43, Garner Spring 2010 Cal Poly, Team 10-43, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G43
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 1,939
