Ana içeriğe geç
Disassembling Siemens A56 Motherboard Metal Frame
Neye ihtiyacın var
  1. Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: adım 1, 3 resimden 1. Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: adım 1, 3 resimden 2. Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: adım 1, 3 resimden 3.
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  2. Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: adım 2, 3 resimden 1. Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: adım 2, 3 resimden 2. Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: adım 2, 3 resimden 3.
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  3. Disassembling Siemens A56 Motherboard Metal Frame: adım 3, 3 resimden 1. Disassembling Siemens A56 Motherboard Metal Frame: adım 3, 3 resimden 2. Disassembling Siemens A56 Motherboard Metal Frame: adım 3, 3 resimden 3.
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
  4. Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: adım 4, 3 resimden 1. Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: adım 4, 3 resimden 2. Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: adım 4, 3 resimden 3.
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
Sonuç
Joseph Casey
409 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G6
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 158
