Ana içeriğe geç
Disassembling Sony Action Cam HDR-AS15 Circuit Board
Neye ihtiyacın var
  1. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Battery: adım 1, 1 resimden 1.
    • To access the battery, gently pry open the rear cover of the action cam.
  2. Disassembling Sony Action Cam HDR-AS15 Circuit Board: adım 2, 2 resimden 1. Disassembling Sony Action Cam HDR-AS15 Circuit Board: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, firmly grip the protrusion where the PULL signifies and remove the tray and battery.
  3. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: adım 3, 3 resimden 1. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: adım 3, 3 resimden 2. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: adım 3, 3 resimden 3.
    • Open the bottom tab with your finger or a plastic opening tool.
    • Pull the tab out, not up, to remove it completely.
    • Remove the two screws from the device.
    • Use your fingers to remove the plastic plate.
  4. Disassembling Sony Action Cam HDR-AS15 Circuit Board: adım 4, 1 resimden 1.
    • Separate the outer casing from the electronics by pushing on one of the ports toward the back end of the case. The electronics should slide right out.
  5. Disassembling Sony Action Cam HDR-AS15 Circuit Board: adım 5, 2 resimden 1. Disassembling Sony Action Cam HDR-AS15 Circuit Board: adım 5, 2 resimden 2.
    • Remove the two 6.4 mm screws on the LCD side of the device using a Phillips #00 screwdriver.
    • Flip the LCD display downward to reveal the circuit board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Scott Scarpinato
185 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Sullivan Winter 2015 USF Tampa, Team 1-2, Sullivan Winter 2015 üyesi
USFT-SULLIVAN-W15S1G2
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,720
