Giriş
You will take apart the camera case to access the circuit board after removing the battery. Be ready to handle small parts and screws.
Neye ihtiyacın var
Open the bottom tab with your finger or a plastic opening tool.
Pull the tab out, not up, to remove it completely.
Remove the two screws from the device.
Use your fingers to remove the plastic plate.
3 farklı kişi bu kılavuzu tamamladı.
