Ana içeriğe geç
Disassembling Sony Clie PEG-NR70 The Case
Neye ihtiyacın var
  1. Disassembling Sony Clie PEG-NR70 The Case, The Case: adım 1, 1 resimden 1.
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Disassembling Sony Clie PEG-NR70 The Case: adım 2, 1 resimden 1.
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Disassembling Sony Clie PEG-NR70 The Case: adım 3, 2 resimden 1. Disassembling Sony Clie PEG-NR70 The Case: adım 3, 2 resimden 2.
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Soski
57 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G11
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 650
