Ana içeriğe geç
Disassembling Sony Clie PEG-SL10
Neye ihtiyacın var
  1. Disassembling Sony Clie PEG-SL10, Disassembling Sony Clie PEG-SL10: adım 1, 1 resimden 1.
    • Start by holding your Sony Clie PEG-SL10 face-up in your hand.
    FixBot'a Sor
    Yorum Ekle
  2. Disassembling Sony Clie PEG-SL10: adım 2, 1 resimden 1.
    • Turn over your Sony Clie and unlock the cover slide lock.
    FixBot'a Sor
    Yorum Ekle
  3. Disassembling Sony Clie PEG-SL10: adım 3, 1 resimden 1.
    • After unlocking the cover slide lock, remove the cover and set aside.
    FixBot'a Sor
    Yorum Ekle
  4. Disassembling Sony Clie PEG-SL10: adım 4, 1 resimden 1.
    • Turn your Sony Clie face-up.
    • Using a Phillips #0 screwdriver, remove the six case screws on the sides and bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  5. Disassembling Sony Clie PEG-SL10: adım 5, 1 resimden 1.
    • Remove the front case by gently lifting away from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Disassembling Sony Clie PEG-SL10: adım 6, 1 resimden 1.
    • Turn the Sony Clie face down and open the back case by prying open the left side of the device.
    • It will open like a book connected by hinges on the right side.
    FixBot'a Sor
    Yorum Ekle
  7. Disassembling Sony Clie PEG-SL10: adım 7, 1 resimden 1.
    • Gently pry off the right side off the back panel and set it aside, leaving room for the scroll wheel at the upper right corner.
    FixBot'a Sor
    Yorum Ekle
  8. Disassembling Sony Clie PEG-SL10: adım 8, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the two screws holding the scroll wheel in place.
    FixBot'a Sor
    Yorum Ekle
  9. Disassembling Sony Clie PEG-SL10: adım 9, 1 resimden 1.
    • Pull out both sides of the clip to remove the scroll wheel power cable from the device.
    FixBot'a Sor
    Yorum Ekle
  10. Disassembling Sony Clie PEG-SL10: adım 10, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew the two screws towards the bottom sides of the Sony Clie to remove the battery harness.
    FixBot'a Sor
    Yorum Ekle
  11. Disassembling Sony Clie PEG-SL10: adım 11, 1 resimden 1.
    • Pull the power cable from the socket located above the upper right side of the battery harness.
    FixBot'a Sor
    Yorum Ekle
  12. Disassembling Sony Clie PEG-SL10: adım 12, 1 resimden 1.
    • Gently pull out the clips to remove the bottom power cables from the motherboard after removing the battery harness.
    FixBot'a Sor
    Yorum Ekle
  13. Disassembling Sony Clie PEG-SL10: adım 13, 1 resimden 1.
    • Rotate the motherboard 180 degrees so that it is upside down facing toward you to expose the power cables on the other side.
    FixBot'a Sor
    Yorum Ekle
  14. Disassembling Sony Clie PEG-SL10: adım 14, 1 resimden 1.
    • Gently pull out the clips to remove the top power cables from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Steve
9 İtibar
1 Kılavuz yazıldı
Ekip
James Madison, Team 1-4, Allen Fall 2011 James Madison, Team 1-4, Allen Fall 2011 üyesi
JMU-ALLEN-F11S1G4
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 39
Her zaman: 2,323
