Ana içeriğe geç
Disassembling Sony Cyber-Shot DSC-W330 Outer Casing
Neye ihtiyacın var
  1. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: adım 1, 3 resimden 1. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: adım 1, 3 resimden 2. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: adım 1, 3 resimden 3.
    • Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
    • Note: There are two (2) screws on each side, and five (5) on the bottom edge.
  2. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 2, 3 resimden 1. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 2, 3 resimden 2. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 2, 3 resimden 3.
    • Use a plastic opening tool to carefully pry off the front casing.
    • Be careful to not to force the casing off. Simply move around the entire case separating where needed.
  3. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 3, 3 resimden 1. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 3, 3 resimden 2. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 3, 3 resimden 3.
    • Flip the camera over 180 degrees and similarly pry off the rear casing.
  4. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 4, 3 resimden 1. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 4, 3 resimden 2. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 4, 3 resimden 3.
    • Once the outer casings have been removed, the silver side trim should come loose from the camera.
    • Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug.
    • Note: If you wish to remove the top cover, see the LCD Display Replacement to remove the LCD screen before continuing to Step 5
  5. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 5, 3 resimden 1. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 5, 3 resimden 2. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: adım 5, 3 resimden 3.
    • Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
    • Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
    • Grasp the top cover and gently remove it from the camera body.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hunter Stewart
411 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-4, Benson Fall 2013 Clemson, Team 13-4, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G4
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 756
