Ana içeriğe geç
Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display
Neye ihtiyacın var
  1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Case: adım 1, 1 resimden 1.
    • Begin by placing the camera upside down and removing the three small center screws.
    • All screws are the same size and length and can be used interchangably.
  2. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 2, 2 resimden 1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 2, 2 resimden 2.
    • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
    • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  3. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 3, 3 resimden 1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 3, 3 resimden 2. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 3, 3 resimden 3.
    • Locate the camera's tripod mount located on the bottom of the camera.
    • Carefully remove the camera's tripod mount and place it aside.
    • Be careful not to lose this piece.
    • Rotate the silver panel labeled 4x clockwise.
  4. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Separating Camera and Display: adım 4, 2 resimden 1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Separating Camera and Display: adım 4, 2 resimden 2.
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  5. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 5, 2 resimden 1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 5, 2 resimden 2.
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  6. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 6, 3 resimden 1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 6, 3 resimden 2. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: adım 6, 3 resimden 3.
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
Sonuç
Steve Van Hall
27 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-3, Benson Spring 2012 Clemson, Team 2-3, Benson Spring 2012 üyesi
CLEM-BENSON-S12S2G3
3 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,686
