Ana içeriğe geç
Disassembling Sony Ericsson QuickShare T630 Phone Enclosure
Neye ihtiyacın var
  1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure, Sony Ericsson QuickShare T630 Phone Enclosure: adım 1, 1 resimden 1.
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 2, 2 resimden 1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 2, 2 resimden 2.
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 3, 1 resimden 1.
    • Slide the battery upward to remove.
  4. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 4, 2 resimden 1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 4, 2 resimden 2.
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 5, 2 resimden 1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 5, 2 resimden 2.
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 6, 1 resimden 1.
    • Slide the aerial upward to remove it.
  7. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 7, 2 resimden 1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 7, 2 resimden 2.
    • Remove the four screws located at each corner of the device.
  8. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 8, 2 resimden 1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 8, 2 resimden 2.
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 9, 3 resimden 1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 9, 3 resimden 2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 9, 3 resimden 3.
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 10, 3 resimden 1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 10, 3 resimden 2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: adım 10, 3 resimden 3.
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christine Becker
101 İtibar
1 Kılavuz yazıldı
Ekip
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013 üyesi
UMAINE-DIAZ-F13S1G13
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 3,530
