Giriş
Use this guide to remove the back cover and access the motherboard.
Neye ihtiyacın var
Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
The panel will slide down about 2mm.
Lift the panel away from the phone.
Insert the edge of an opening tool between the back cover and the phone body on the top edge (not to be confused with the edge where the phone slides).
Pry the back case off of the phone working your way around the edges until the panel is freed from the phone.
4 farklı kişi bu kılavuzu tamamladı.
