Ana içeriğe geç
Disassembling Sony Ericsson w600i Back Housing
Neye ihtiyacın var
  1. Disassembling Sony Ericsson w600i Back Housing, Disassembling Sony Ericsson w600i Battery Cover: adım 1, 1 resimden 1.
    • Grip the lower portion of the back of the phone and slide downwards.
  2. Disassembling Sony Ericsson w600i Back Housing, Battery: adım 2, 1 resimden 1.
    • Lift battery at the rounded notch near the bottom of the phone.
  3. Disassembling Sony Ericsson w600i Back Housing, Back housing: adım 3, 1 resimden 1.
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  4. Disassembling Sony Ericsson w600i Back Housing: adım 4, 1 resimden 1.
    • Swivel the phone open.
  5. Disassembling Sony Ericsson w600i Back Housing: adım 5, 1 resimden 1.
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  6. Disassembling Sony Ericsson w600i Back Housing: adım 6, 1 resimden 1.
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  7. Disassembling Sony Ericsson w600i Back Housing: adım 7, 1 resimden 1.
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  8. Disassembling Sony Ericsson w600i Back Housing: adım 8, 2 resimden 1. Disassembling Sony Ericsson w600i Back Housing: adım 8, 2 resimden 2.
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  9. Disassembling Sony Ericsson w600i Back Housing: adım 9, 3 resimden 1. Disassembling Sony Ericsson w600i Back Housing: adım 9, 3 resimden 2. Disassembling Sony Ericsson w600i Back Housing: adım 9, 3 resimden 3.
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  10. Disassembling Sony Ericsson w600i Back Housing: adım 10, 1 resimden 1.
    • The back housing is now disassembled, and the swivel assembly is revealed.
Sonuç
Beau Blanchard
20 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 429
