Ana içeriğe geç
Giriş
This a simple process requiring only a small Phillips screwdriver and a slim flathead.
Note: A few trays for the screws, a wristband and an anti-static surface mat are ideal for safe handling of sensitive electronics.
  1. - Remove battery.
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. - Remove CD/DVD Drive by sliding it out.
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  5. - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  6. - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  7. - Fire up the air compressor and blow out dust from the fan and heatsinks.
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  8. - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Artem Nikulkov
259 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 2
Son 30 Gün: 15
Her zaman: 20,481
