Ana içeriğe geç
Disassembling Soundmates V2 Case
Neye ihtiyacın var
    1. Disassembling Soundmates V2 Case, Soundmates V2 Case: adım 1, 2 resimden 1. Disassembling Soundmates V2 Case, Soundmates V2 Case: adım 1, 2 resimden 2.
      • Flip open the cover and insert a thin flathead screwdriver in the seam by the hinge
      • Rotate the screwdriver just enough to create a gap between the two halves of the case
      • If this doesn't work very well, try the other side
      • Insert a spudger or another flathead bit into the new gap
      • This may cause some cosmetic damage
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling Soundmates V2 Case: adım 2, 3 resimden 1. Disassembling Soundmates V2 Case: adım 2, 3 resimden 2. Disassembling Soundmates V2 Case: adım 2, 3 resimden 3.
      • Once you've created a small gap, the lid should come off fairly easily
      • Run the spudger around the case until the two halves separate
      • If the top half doesn't come straight up and out, it may break off the charging port, like it did with mine. Go slowly and use caution
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling Soundmates V2 Case: adım 3, 1 resimden 1.
      • Remove the two Philips #00 screws securing the board
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling Soundmates V2 Case: adım 4, 1 resimden 1.
      • Gently lift the circuitboard off. Not too high; it's still wired to the battery
      • Now just pull off the battery; it's only held down by a sticky foam pad
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling Soundmates V2 Case: adım 5, 1 resimden 1.
      • Done! Hope you didn't break anything like I did.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
darth mango
3.814 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 58
Her zaman: 1,243
