Ana içeriğe geç
Disassembling Speak And Spell Case
Neye ihtiyacın var
  1. Disassembling Speak And Spell Case, Case: adım 1, 2 resimden 1. Disassembling Speak And Spell Case, Case: adım 1, 2 resimden 2.
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: adım 2, 1 resimden 1.
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
Sonuç
bushing
10.250 İtibar
13 adet Kılavuz yazıldı
Bir Yorum
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 4,960
