Ana içeriğe geç
Disassembling Sprint Sanyo RL-4920 Outer Case
Neye ihtiyacın var
  1. Disassembling Sprint Sanyo RL-4920 Outer Case, Back of Phone: adım 1, 1 resimden 1.
    • Flip the phone over so that the screen is facing down.
  2. Disassembling Sprint Sanyo RL-4920 Outer Case, Remove Battery Pack: adım 2, 2 resimden 1. Disassembling Sprint Sanyo RL-4920 Outer Case, Remove Battery Pack: adım 2, 2 resimden 2.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Disassembling Sprint Sanyo RL-4920 Outer Case, Screws: adım 3, 2 resimden 1. Disassembling Sprint Sanyo RL-4920 Outer Case, Screws: adım 3, 2 resimden 2.
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Disassembling Sprint Sanyo RL-4920 Outer Case, Separate Cases: adım 4, 1 resimden 1.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Disassembling Sprint Sanyo RL-4920 Outer Case, Separate Cases: adım 5, 1 resimden 1.
    • Separate the two cases.
  6. Disassembling Sprint Sanyo RL-4920 Outer Case, The Front Case: adım 6, 1 resimden 1.
    • Use the plastic opening tool to remove the motherboard from the front case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Shores
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 241
