Ana içeriğe geç
Disassembling the Teac DC-D2831
Neye ihtiyacın var
  1. Disassembling the Teac DC-D2831, Disassembling the Teac DC-D2831: adım 1, 1 resimden 1.
    • Make sure the device is turned off and unplugged. This will eliminate the danger of getting electrocuted while repairing the device or damaging components.
  2. Disassembling the Teac DC-D2831: adım 2, 2 resimden 1. Disassembling the Teac DC-D2831: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the lid to get to the turntable.
    • Using the appropriate tools (needle-nose pliers, tweezers, screwdriver, etc.), remove the snap ring from the center of the turntable. The snap-ring is the small metal ring around the axel of the turntable.
    • The snap-ring is hard to remove so be patient and don't be afraid to use some force.
    • Feel free to use whatever tool(s) that will remove the snap-ring. The above list of tools are just a suggestions.
  3. Disassembling the Teac DC-D2831: adım 3, 2 resimden 1. Disassembling the Teac DC-D2831: adım 3, 2 resimden 2.
    • Gently lift the turntable from the rest of the device.
    • If the device has a faulty belt, see the belt repair guide here: Belt Repair Guide
  4. Disassembling the Teac DC-D2831: adım 4, 1 resimden 1.
    • Remove the screws on the side of the device using a Phillips #2 screwdriver.
    • When removing the screws, take note of which screws go where.
    • 27.0mm
    • 19.8mm
    • 12.0mm
  5. Disassembling the Teac DC-D2831: adım 5, 2 resimden 1. Disassembling the Teac DC-D2831: adım 5, 2 resimden 2.
    • Lift the base that the turntable was resting on from the rest of the device.
    • Remove the base slowly so to not sever the connection with the wire attached from the base to the circuit board.
  6. Disassembling the Teac DC-D2831: adım 6, 1 resimden 1.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jake Hamilton
167 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G61
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
How to remove lid from CD-D2831
jfranklinhamm - Yanıt
So radio sound and tape work and sound is great. However when turn table is on the sound is low only on that component any help would be greatly appreciated
Joanna Chavez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 4,681
