Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Open the phone so that it matches the photos to the left.
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
