Ana içeriğe geç
Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies
Salt Önkoşul
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: adım 2, 1 resimden 1.
    • Gently lift the battery out of the computer.
  3. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies, Upper Assembly: adım 3, 1 resimden 1.
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: adım 4, 1 resimden 1.
    • Remove the WIFI module cover. It will pull right off.
  5. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: adım 5, 2 resimden 1. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: adım 5, 2 resimden 2.
    • Unplug the white and black wires from the WiFi module.
  6. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: adım 6, 1 resimden 1.
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: adım 7, 1 resimden 1.
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: adım 8, 1 resimden 1.
    • Use the plastic opening tool to pry the two halves apart.
Sonuç
Geoff Wacker
87.853 İtibar
89 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 228
