Ana içeriğe geç
Disassembling Toshiba T1960CS for HDD Removal
Neye ihtiyacın var
  1. Disassembling Toshiba T1960CS for HDD Removal, HDD Removal: adım 1, 1 resimden 1.
    • Pry up cover, remove screw.
  2. Disassembling Toshiba T1960CS for HDD Removal: adım 2, 1 resimden 1.
    • Remove screws.
  3. Disassembling Toshiba T1960CS for HDD Removal: adım 3, 1 resimden 1.
    • Gently pry out to unsnap top plastic housing.
  4. Disassembling Toshiba T1960CS for HDD Removal: adım 4, 1 resimden 1.
    • Lift keyboard and flip over, but do not remove, it is still attached by ribbon cable.
    • Slide back connector tabs to release ribbon cable.
    • Remove 5 screws and lift out plate to access HDD and FDD.
  5. Disassembling Toshiba T1960CS for HDD Removal: adım 5, 1 resimden 1.
    • To remove HDD loosen tape, lift out BIOS battery, remove screws and slide back HDD housing.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
WayneG
191 İtibar
1 Kılavuz yazıldı
Bir Yorum
The plastic housing does not come off. It seems to be attached to the screen
James Blimthorpe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 3,316
