Ana içeriğe geç
Disassembling UPS OVISLINK TRACITE CUBE or CUBO All
Neye ihtiyacın var
  1. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Unscrew the front panel: adım 1, 3 resimden 1. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Unscrew the front panel: adım 1, 3 resimden 2. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Unscrew the front panel: adım 1, 3 resimden 3.
    • Before you begin, be sure to shut off the UPS and unplug it. You do not want the UPS to kick in while you're performing the procedure.
    • Remove the screws (2) under the device
  2. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Open the front pannel: adım 2, 3 resimden 1. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Open the front pannel: adım 2, 3 resimden 2. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Open the front pannel: adım 2, 3 resimden 3.
    • Slide the front pannel up
  3. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the Bottom pannel: adım 3, 3 resimden 1. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the Bottom pannel: adım 3, 3 resimden 2. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the Bottom pannel: adım 3, 3 resimden 3.
    • Remove left/right clips. And remove the bottom pannel
  4. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the Battery: adım 4, 1 resimden 1.
    • Be careful
  5. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the left side: adım 5, 3 resimden 1. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the left side: adım 5, 3 resimden 2. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the left side: adım 5, 3 resimden 3.
    • Unclip the left pannel
  6. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the right side: adım 6, 3 resimden 1. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the right side: adım 6, 3 resimden 2. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the right side: adım 6, 3 resimden 3.
    • Unclip the right pannel
  7. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the rear pannel: adım 7, 1 resimden 1.
    • Caution when pluging the rear pannel...
    • -blue for neutral.
    • -yelow/green for earth
    • -brown for phase
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
pldestin
128 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 1,234
