Ana içeriğe geç
Disassembling VTech MobiGo Touch Learning System Keyboard
Neye ihtiyacın var
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: adım 1, 1 resimden 1.
      • Remove the battery covers and the four batteries.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 2, 2 resimden 1. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 2, 2 resimden 2.
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 3, 2 resimden 1. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 3, 2 resimden 2.
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      FixBot'a Sor
      Yorum Ekle
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: adım 4, 2 resimden 1. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: adım 4, 2 resimden 2.
      • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
      • Use light pressure to prevent damage to the circuit board.
      FixBot'a Sor
      Yorum Ekle
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 5, 1 resimden 1.
      • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
      • Once the screw is removed, remove the blue plastic cover.
      FixBot'a Sor
      Yorum Ekle
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 6, 2 resimden 1. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 6, 2 resimden 2.
      • Remove the two 4.0 mm Philips J0 screws located on the orange case.
      • Use gentle force to prevent stripping of screws.
      FixBot'a Sor
      Yorum Ekle
    4. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 7, 3 resimden 1. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 7, 3 resimden 2. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 7, 3 resimden 3.
      • Remove the two "L" shaped brackets located on both sides of the device.
      • Use the magnetic mat to store these brackets.
      FixBot'a Sor
      Yorum Ekle
    5. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 8, 1 resimden 1.
      • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
      FixBot'a Sor
      Yorum Ekle
    6. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 9, 2 resimden 1. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 9, 2 resimden 2.
      • Gently lift the circuit board from the case using a plastic opening tool.
      • Make sure to use a plastic opening tool for this step.
      FixBot'a Sor
      Yorum Ekle
    7. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 10, 1 resimden 1.
      • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
      • Keep the circuit board out of the way to avoid damaging it.
      FixBot'a Sor
      Yorum Ekle
    8. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 11, 1 resimden 1.
      • Slowly remove the keyboard panel.
      • Use a spudger if necessary.
      • The keys will fall out once the keyboard panel is removed.
      • Remove all of the keys and set them aside with the keyboard panel.
      FixBot'a Sor
      Yorum Ekle
    9. Disassembling VTech MobiGo Touch Learning System Keyboard: adım 12, 1 resimden 1.
      • Gently remove the keyboard circuit board with a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
Sonuç
RBansil
221 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G3
3 Üyeler
17 adet Kılavuz yazıldı
1Rehber Yorum
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 2,452
