Neye ihtiyacın var
10 Yorum
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
how do you fix that i have busted screen on a bar 800 and need directions
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic -
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V -
To solve the missing digits and segments on the LCD, in my case I just inserted a small bent paper on the flat white cable (strip) to add a small bit of more pressure into the connectors.
You can read more on Stackexchange searching for partially-broken-lcd-missing-segments
JCM -
