Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Oregon Scientific Ultra Thin Weather Station cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Disassembling Weather Box Oregon BAR800, Disassembling Weather Box Oregon BAR800: adım 1, 1 resimden 1.
    • Weather Box, front side
    FixBot'a Sor
  2. Disassembling Weather Box Oregon BAR800: adım 2, 3 resimden 1. Disassembling Weather Box Oregon BAR800: adım 2, 3 resimden 2. Disassembling Weather Box Oregon BAR800: adım 2, 3 resimden 3.
    • Rear side
    FixBot'a Sor
  3. Disassembling Weather Box Oregon BAR800: adım 3, 1 resimden 1.
    • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • Be carefull to not damage external plastic with knife
    FixBot'a Sor
  4. Disassembling Weather Box Oregon BAR800: adım 4, 3 resimden 1. Disassembling Weather Box Oregon BAR800: adım 4, 3 resimden 2. Disassembling Weather Box Oregon BAR800: adım 4, 3 resimden 3.
    • After plastic screen removed, it can see the screws.
    • With a small screw driver, take them off. There are eight screws.
    FixBot'a Sor
  5. Disassembling Weather Box Oregon BAR800: adım 5, 1 resimden 1.
    • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
    FixBot'a Sor
  6. Disassembling Weather Box Oregon BAR800: adım 6, 3 resimden 1. Disassembling Weather Box Oregon BAR800: adım 6, 3 resimden 2. Disassembling Weather Box Oregon BAR800: adım 6, 3 resimden 3.
    • Internal view
    FixBot'a Sor
Andres
110 İtibar
1 Kılavuz yazıldı
10Kılavuz Yorumları
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - Yanıt Paylaş
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel - Yanıt Paylaş
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic - Yanıt Paylaş
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V - Yanıt Paylaş
To solve the missing digits and segments on the LCD, in my case I just inserted a small bent paper on the flat white cable (strip) to add a small bit of more pressure into the connectors.
You can read more on Stackexchange searching for partially-broken-lcd-missing-segments
JCM - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 39
Her zaman: 3,809
