Neye ihtiyacın var
Locate 2 small phillips-head screws under the middle-top and bottom of the bar code sticker on bottom of drive. Uncover screws and loosen.
Feel around on the sticker for two depressions in which the screws are sunk. On the 2014U model, the one depression is under the “al” of Western Digital” at the top and the other is near the UL symbol at the bottom.
With all the black trim taken off, five tabs will be exposed. one on the front, one on the left and three on the right.
The tabs have three small marks/dots on them. The three dots are tabs that poke into three holes in the tabs behind them, so put the small flathead screwdriver in between the two tabs in a downward direction, prying the five tabs out of their holes and lift gently.
At the back of the drive, pry away the four metal tabs on the left and right holding down the metal bracket at the back of the drive. A fourth strip of metallic tape may cover two of these tabs rearmost on the drive. Look for the bumps under the tape.
Score / cut / remove the metallic tape that holds the back of the metal bracket to the back of the carriage assembly.
