Ana içeriğe geç
Disassembling Western Digital Elements SE HD case and mainboard
Neye ihtiyacın var
  1. Disassembling Western Digital Elements SE HD case and mainboard, Opening the case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • The case can be opened easily with a plastic case opening tool. Strong finger nails and an old credit card / plastic card may work too.
  2. Disassembling Western Digital Elements SE HD case and mainboard, Remove marked screws (T5): adım 2, 1 resimden 1.
    • The 5 marked screws can be removed with a Torx T5.
  3. Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: adım 3, 2 resimden 1. Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: adım 3, 2 resimden 2.
    • Lift the board gently - there is only one small connector connecting the board to the hard disk case (around the yellow market space).
    • On the second image, you can see the board turned over.
    • Further disassembly would damage the disk. I hoped to find a SATA connector within, but maybe someone knows an alternative board with the same connector.
  4. Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: adım 4, 2 resimden 1. Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: adım 4, 2 resimden 2.
    • The label on the WD Elements SE case and the labels on the harddisk can be seen here. I censored serial numbers, the WWID and the barcodes.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bastli
283 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 26
Son 30 gün: 105
Her zaman: 1,662
