Ana içeriğe geç
Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard
Neye ihtiyacın var
  1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: adım 1, 3 resimden 1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: adım 1, 3 resimden 2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: adım 1, 3 resimden 3.
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: adım 2, 2 resimden 1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: adım 2, 2 resimden 2.
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, LED Light conducting plastic pieces: adım 3, 1 resimden 1.
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: adım 4, 3 resimden 1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: adım 4, 3 resimden 2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: adım 4, 3 resimden 3.
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: adım 5, 2 resimden 1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: adım 5, 2 resimden 2.
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: adım 6, 2 resimden 1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: adım 6, 2 resimden 2.
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: adım 7, 1 resimden 1.
    • Remove the rubber piece from the SATA/USB bridge logic board.
  8. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: adım 8, 2 resimden 1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: adım 8, 2 resimden 2.
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  9. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: adım 9, 1 resimden 1.
    • Remove both screws holding the retaining plate with the logic board.
Sonuç
Gaetan
9.586 İtibar
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 2,130
