Ana içeriğe geç
Disassembling Xbox 360 E Bottom Body
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Disassembling Xbox 360 E Bottom Body, Top Panel: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Spudger
    $2.99
    Satın Al
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Disassembling Xbox 360 E Bottom Body: adım 2, 1 resimden 1.
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Disassembling Xbox 360 E Bottom Body: adım 3, 3 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 3, 3 resimden 2. Disassembling Xbox 360 E Bottom Body: adım 3, 3 resimden 3.
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. Disassembling Xbox 360 E Bottom Body, Bottom Panel: adım 4, 1 resimden 1.
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  5. Disassembling Xbox 360 E Bottom Body: adım 5, 2 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 5, 2 resimden 2.
    • Slide the spudger along the crevice to separate the grated face and the top body.
  6. Disassembling Xbox 360 E Bottom Body: adım 6, 3 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 6, 3 resimden 2. Disassembling Xbox 360 E Bottom Body: adım 6, 3 resimden 3.
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  7. Disassembling Xbox 360 E Bottom Body, Front Panel: adım 7, 3 resimden 1. Disassembling Xbox 360 E Bottom Body, Front Panel: adım 7, 3 resimden 2. Disassembling Xbox 360 E Bottom Body, Front Panel: adım 7, 3 resimden 3.
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
  8. Disassembling Xbox 360 E Bottom Body: adım 8, 3 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 8, 3 resimden 2. Disassembling Xbox 360 E Bottom Body: adım 8, 3 resimden 3.
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
  9. Disassembling Xbox 360 E Bottom Body: adım 9, 3 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 9, 3 resimden 2. Disassembling Xbox 360 E Bottom Body: adım 9, 3 resimden 3.
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
  10. Disassembling Xbox 360 E Bottom Body: adım 10, 3 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 10, 3 resimden 2. Disassembling Xbox 360 E Bottom Body: adım 10, 3 resimden 3.
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
  11. Disassembling Xbox 360 E Bottom Body: adım 11, 2 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 11, 2 resimden 2.
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
  12. Disassembling Xbox 360 E Bottom Body: adım 12, 3 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 12, 3 resimden 2. Disassembling Xbox 360 E Bottom Body: adım 12, 3 resimden 3.
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
  13. Disassembling Xbox 360 E Bottom Body, Bottom Body: adım 13, 3 resimden 1. Disassembling Xbox 360 E Bottom Body, Bottom Body: adım 13, 3 resimden 2. Disassembling Xbox 360 E Bottom Body, Bottom Body: adım 13, 3 resimden 3.
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
  14. Disassembling Xbox 360 E Bottom Body: adım 14, 2 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 14, 2 resimden 2.
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
  15. Disassembling Xbox 360 E Bottom Body: adım 15, 3 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 15, 3 resimden 2. Disassembling Xbox 360 E Bottom Body: adım 15, 3 resimden 3.
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
  16. Disassembling Xbox 360 E Bottom Body: adım 16, 2 resimden 1. Disassembling Xbox 360 E Bottom Body: adım 16, 2 resimden 2.
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
Sonuç
Sarah
1.732 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G11
4 Üyeler
43 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 89
