Ana içeriğe geç
Disassembling Yamaha YPG-225 Faceplate
Neye ihtiyacın var
  1. Disassembling Yamaha YPG-225 Faceplate, Batteries: adım 1, 1 resimden 1.
    • Turn the keyboard over so that the keys are facing the ground.
  2. Disassembling Yamaha YPG-225 Faceplate: adım 2, 1 resimden 1.
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Disassembling Yamaha YPG-225 Faceplate: adım 3, 1 resimden 1.
    • Locate the six batteries and remove them from the battery cavity.
  4. Disassembling Yamaha YPG-225 Faceplate, Faceplate: adım 4, 1 resimden 1.
    • Remove the six 10mm screws at the top of the backplate.
  5. Disassembling Yamaha YPG-225 Faceplate: adım 5, 1 resimden 1.
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Disassembling Yamaha YPG-225 Faceplate: adım 6, 1 resimden 1.
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Disassembling Yamaha YPG-225 Faceplate: adım 7, 1 resimden 1.
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Disassembling Yamaha YPG-225 Faceplate: adım 8, 2 resimden 1. Disassembling Yamaha YPG-225 Faceplate: adım 8, 2 resimden 2.
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
Sonuç
Lonnie Bissmeyer
468 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-62, Propen Fall 2012 Cal Poly, Team 2-62, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G62
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 1,680
